What role is required to create a CI?
Lalitha6
Kilo Explorer
HI,
Which role is requried to create a CI in cmdb table.
For ITIL role, will the NEW button is visible or not?
HI Swetha,
I have checked the ACL which u have told. Are are perfect but still i couldnt found it when i am impersonating the user.
Pls refer the screenshot attached
Does that user has any one of role among asset and config-librain ???
yes he is having the role of Asset
User177031
Hi Lalitha,
Are you looking for 'New' button on cmdb_ci table? Please check 'Create' ACL on the table which you are looking for. Also check the condition on UI action.
Thank you.
