work note after RITM state change to Closed
Avdhoot
I want to add auto work note if RITM state changes to closed, I am able to achieve through the business rule.
If there are multiple SCTASK after work note is posted automatically the state changes back to work in progress from closed. And if single SCTASK is there its working fine
condition:
on before, insert update are true
State changes to closed
code:
// Add your code here
current.work_notes = gs.getMessage(' this request is closed.');
})(current, previous);
Check for a other BR on RITM or Task table, which may be doing that....Also check the workflow associated to the RITM.
