ā02-22-2022 06:11 AM
ā02-22-2022 07:56 AM
Are the field names correct? can you check if the application has business owner mapped? if yes also verify if owner is active or not.
keep log and verigy the values
gs.info("business owner: "+current.variables.application.u_business_owner.toString());
answer =[];
answer.push(current.variables.application.u_business_owner.toString());
ā02-22-2022 06:41 AM
Then, use the below code simply.
var Req = current.variables.request_for;
var techapr = current.variables.application.u_business_owner.toString();
if (techapr[i] != Req)
answer.push(techapr);
//Answer variable can't take true false value here.
ā02-22-2022 06:48 AM
Not working
ā02-22-2022 06:55 AM
Use this. Sorry for the typo. Please user below one.
//I hope you want to skip the approval if the requestor for is the owner right?
// Please change the variable names as per your name.
var Req = current.variables.request_for+"";
var techapr = current.variables.application.u_business_owner+"";
if (techapr!= Req)
ā02-22-2022 06:26 AM
ā02-22-2022 06:33 AM
Hi suresh
Is business owner field type reference?
