XML data extract
shohebshaikh
Giga Expert
How do I extract data of the 'sys_audit', 'sys_choice', and 'sys_attachment' table for Incident table.
Chuck Tomasi
Hi Shoheb,
All three tables have a table field on them. You can simply filter on that.
Use the navigator filter to go to sys_choice.list (or sys_attachment.list), filter on the correct value in the correct field, then right click Export> XML.
sys_audit is potentially very large and I don't recommend exporting it unless absolutely necessary. Often times, taking the history from one instance to another is not mandatory.
Exporting and Importing XML Files - ServiceNow Wiki
11 REPLIES 11
When you look at this list filter, is there a Domain field option in the field picker? If so, use that to filter on the domain. I don't have immediate access to a domain separated instance so I cannot verify if this table is domain separated or not.
shohebshaikh
Giga Expert
Hi Chuck,
There is no Domain field option in the filter.
Without a domain field, there's no way to get just the audit records for a particular domain then.
Forgive me if I've already asked... what is the business requirement behind extracting information from a single domain from the sys_audit table?
shohebshaikh
Giga Expert
It is just the reqirement which we got. We dont knw the reason behind it.
Thank you Shoheb. Unfortunately, you won't be able to meet this particular requirement.
