Caller Authentication does not work using twilio provider
User687957
Mega Guru
Dear all,
I have setup an Assistant provider as twilio for testing voice agent.From the configuration below I have setup the KBA for caller identification through phone number and set the caller authentication as Auth App
When calling the voice agent number, I manage to get identified by phone number but the second step for Auth App authentication fails all time by typing correct number
I have also try as MPF to set the SoftPin first but same thing
I have the feeling that MFA did not work at all in such context
Any one have experience this issue and any idea how to solve ?
regards
thanks a lot, Is there any workable solution they provided, or it is background script?
PaulSylo
To be is to do. To do is to be.
Hello @Paulsylo this is a background script that they correct on my instance because I get an imporant customer demo
Thanks ! I fixed it by mapping right deployment and mapping to right service mapping
PaulSylo
