Best way to connect ServiceNow to Power BI?
NomisKeem
Kilo Explorer
Hello all,
I am currently working on a process to connect our ServiceNow instance to Power BI. I wanted to ask about best options and practices. I am considering connecting an ODBC driver to our ServiceNow instance which will then connect to a SQL server database which will connect to the dashboard I have created.
Is this the best way to go about the connection or is there a better way? Also is the SQL database really necessary or will only using the ODBC driver suffice?
Thanks.
sachin_namjoshi
Mega Patron
PowerBI provides REST API.
You can use REST API to integrate both the platforms.
Sachin
Thanks for the advice, would you say that it's better than using an ODBC driver?
Hi Sachin, can you evaborate how to integrate using Rest message API.
Hi @sachin_namjoshi ,
can you help me on this issue, iam getting credential issues, what could be cause to get following error.
