08-18-2022 01:36 AM
Hi community!
I'd like to know if there's a way (or if it is possible) to create a report joining RITM variable sets and Multi-row Variable sets in one report.
Reporting
08-18-2022 01:45 AM
HI Erika,
You can actually report on MRVS by creating a database view, then use that view to report on
- Create a new Database view (System Definition -> Database Views)
- Give it a name like 'u_sc_req_item_multi_var'
- Label like "Multi Row Variable Set"
- Plural like "Multi Row Variable Sets"
- Description like "Joins the sc_req_item to the Multi Row variable set table to be able to report"
- Save
- Under View Tables click "New"
- Table: Requested Item [sc_req_item]
- Variable Prefix: sci
- order: 100
- Where clause: mrqa_parent_id = sci_sys_id
- Click "Submit"
- Table: Multi Row Question Answer [sc_multi_row_question_answer]
- Variable Prefix: mrqa
- order: 100
- Where clause: keep this field blank
- Click "Submit"
You should now have a DBV that looks something like this:
Create a new report
Select Table as source and select your new Database view (Multi Row Variable Set) as the table
You should now be able to create a query and select the catalog item that you want to report on that has the MRVS, as well as adjust your columns to display the Question and Value as well as any other columns you want on your report.
Referred from this thread :https://community.servicenow.com/community?id=community_question&sys_id=252bce56dbd363809a64e15b8a96...
Sandeep
02-09-2025 01:12 AM
Follow below steps to join Req item table with Multi row variables table:
- Step 1: -
Create a Database View as show below in screen grab.
- Step 2: - verify the data is visible on the table.
- Step 3: - create the report.
If this response is useful, please mark it as helpful.
