Delete multiple records using background scripts
Lucien1
Giga Expert
Hi all,
I have modified this script I found to try delete multiple records but so far it fails.
I am going to be using the scripts background function as it is just a 1 time event. The records are before the 1st of April so I added an encoded query. Can anyone see where I am going wrong as I can't sit and delete all these records manually.
var gr = new GlideRecord('pa_scores');
gr.addQuery('breakdown','=', 'Model Category');
gr.addEncocdedQuery(sys_created_on<=javascript:gs.dateGenerate('2016-03-31','23:59:59'));
while (gr.next()) {
    //Delete each record in the query result set
  gr.deleteRecord();
Lucien
Lucien1
Giga Expert
Thanks all for your help and with a bit of changes with your guidance I got it working. Below is what I have used.
gr.addQuery('breakdown.name','=', 'Model Category'); // Pradeep Sharma update
gr.addEncodedQuery('sys_created_on<=' + gs.dateGenerate('2016-03-31','23:59:59')); // Chuck Tomasi update
while (gr.next()) {
  gr.deleteMultiple(); // Ken and Santosh update
It still took time to delete these records (Dev instance 1st) but now that I know it works I can do this in production.
15 REPLIES 15
j_15
The accepted solution is sub-optimal. There is no need to put deleteMultiple() in a loop. It will iterate over the records returned within the GlideRecord object by itself.
