Difference between pa_dashboards and par_dashboards tables?
04-10-2026 09:55 AM
Hi everyone,
I had a question regarding Performance Analytics dashboards and was hoping someone could clarify.
What is the difference between pa_dashboards and par_dashboards tables in ServiceNow?
In my PDI, I can see both of these tables present, even though Classic Reporting appears to be disabled. This has caused some confusion about their respective purposes and when each is used.
Are both tables actively used in newer versions?
Is one related to legacy (Classic) reporting and the other to Workspace/Next Experience dashboards?
Should we prefer one over the other for new implementations?
Any insights or documentation references would be really helpful.
Thanks in advance!
04-14-2026 08:23 AM
Hello @skhaire ,
I hope you are doing well . Does my response helps you ?
If my response helps you then mark it as helpful and accept as solution.
Aditya
