Metrics are not visible under metric definition for sc_req_item table.
Kartik Swaroop
Hi ,
I've created a metrics for request item table but records are not visible.
Would you guys please help here,  i need to create a metric report for request item table.
Hello Kartik,
It seems you have create correct metrics definition.
Kindly note that this definition works only on tickets whose assignment group changed after creating this definition.
If you are still facing the issue, please let me know.
11 REPLIES 11
It will work on previous records if assignment group changes now (after creation of definition)
But it doesn't work on records where assignment group is changed before definition is created.
For example,
- If definition created at 13-06-2022 10:15 AM, if assignment group changed at 13-06-2022 11:13 AM, then this record is captured under metrics.
-  If definition created at 13-06-2022 10:15 AM, if assignment group changed at 13-06-2022 09:13 AM, then this record is NOT captured under metrics.
I hope it's clear now.
Thanks bud.
Is there any other way to find out the assignment group duration or previously created records, whenever they changed to different group ?
Hello Kartik,
Unfortunately there is no way to find this duration. Assignment group changed is being captured in the table "sys_history_line". This is basically audit history table and having huge amount of data also didn't have duration calculation.
But you can check once if it helps you.
Hi, just wanna ask if it's possible for the sys_req_item table and sys_history_line table to be combined in a database view? Is it possible?
