Report on Dashboard not allowing drill down for other users
Cat
We have a user who has added a chart to a dashboard as a widget. When they click on any of the bars, it takes them to a page with a list view of that information. However, when someone else on their team clicks on the bar, they get a message: "Security constraints prevent access to requested page"
The users have access to the Dashboard and chart - why does this occur for them?
@Cat
it looks like that is a database view joining multiple tables and hence not showing up in the Access Analyzer
share how your report is configured
Is it using some group by etc
In left nav search database view and search that here
-> try creating that table.None READ ACL with snc_internal role
19 REPLIES 19
When I search for it, it doesn't appear. This is why I'm so confused:
The ones I've blurred are not what I am looking for
Hi @Cat
Is this a system/custom table, or did you create this table yourself?
Sandeep Rajput
@Dr Atul - LNG Thanks for the mention. @Cat The user who are seeing this issue may not have read/report_viewer access to the underlying table.
To debug the ACL issue, you can use Access Analyser  to find the problematic ACL.
It shows here as a table:
But not here:
Ankur Bawiskar
@Cat
Approach shared by @Sandeep Rajput to debug will lead you to identify the root cause and the fix
