Instance Not Recovering from Offline Status
としのりた
At 18:10 UTC on October 30, when I attempted to access my PDI (Personal Developer Instance), I found that the instance was still showing as Offline in the Developer Portal.
I tried refreshing the status, logging out and back into the Developer Portal, and accessing the instance directly via its URL. However, the status has not changed.
The Actions menu only displays the following options, and there are no options to wake up or start the instance:
  • Release instance
  • View history
My instance is still listed in the Developer Portal. I have also not received any email notification regarding the reclamation of my instance.
Since I would like to preserve my existing data, I have not selected Release instance.
Could you please advise how I can determine whether my instance has already been reclaimed, is currently undergoing the reclamation process, or if this is an issue with the PDI infrastructure?
Thank you for your assistance.
Best regards,
Hi @としのりた,
That sounds like a good approach.
If you decide to move to a new instance, capturing your work through an Update Set and taking regular checkpoints/backups is definitely a good practice. This can help you preserve your configuration and reduce the effort required if you face a similar issue again.
Also, where possible, consider using Source Control for application development, as Update Sets may not capture every type of configuration or data.
I hope your new instance setup goes smoothly!
Accept the solution if it assisted you with your question & Mark this response as Helpful.
Tarun
Aditya_hublikar
Hello @としのりた ,
If you got email for reclaimation then only it will get reclaimed as far i know .  Unfortunately  there is no any solution  for this .
Nowdays this is common issue faced by multiple users . My PDI also went to Offline since yesterday . But dont worry in rare situation pdi dont get back online . We can just keep some patience for while . Always keep in mind if you are doing any business requirement task on pdi then always takes its backup even if task is in progress or completed so it will help in such situations .
You can also refer this servicenow admin ressponses
https://www.servicenow.com/community/developer-forum/pdi-dev443121-offline-502-snow-adc-no-wake-opti...
https://www.servicenow.com/community/developer-forum/my-developer-instance-is-offline/m-p/3614836/hi...
If this helps you then mark it as helpful and accept as solution .
Aditya
