Shopping Hub error: Page not found prompt after installing plugin
Kevin Recio
After installing the ShoppingHub plugin as well as the Procurement Management family pack, I am getting a "Page not found" error when attempting to navigate to my instance of ShoppingHub.
I can see ShoppingHub in my filter navigator:
However, when I click the menu option to open in a new tab, I receive the error message page:
I can confirm via the plugins page that I have it installed, along with dependent plugins:
Appreciate any help or guidance with this product. Thank you.
rafael_merces2
Kevin, while installing this in my instance I noticed the same error. I believe the OOTB hyperlink is wrong. Try to access "/now/psm/shoppinghub".
Hi @AlexandraJ did you raise a support case for this issue? I am a product manager supporting Shopping Hub. I wanted to see if I could follow up and investigate this issue. If you are able to share this support ticket # it would be much appreciated.
Hello Matt.
Thanks for replying. I found a technical issue, released my PDI and requested a new one. Then, it worked fine 🙂 Thanks for your support.
BR, Alexandra
