difference between system property and base property
09-11-2025 12:26 PM
please specify detailed differences ?
09-11-2025 08:00 PM - edited 09-11-2025 08:01 PM
Hi @sagarpundir ,
Not sure what you meant by 'base property' here. ServiceNow provides properties for various use cases, including platform-level properties that are stored in the sys_properties table. You can update these properties or create new ones as needed.
Example: com.glide.attachment.max_size — Controls the maximum file attachment size in megabytes
Do you have any examples??? so that we can explain.
09-11-2025 08:08 PM
Hi @sagarpundir ,
Base properties- OOB System properties. The term "base properties" in ServiceNow typically refers to the fundamental, out-of-the-box properties and attributes inherent to a record or table. These are the core fields and characteristics that define a specific record type
System Properties - OOB or Customer System Properties.
System properties are key-value pairs stored in the sys_properties table in ServiceNow. They are used to store configuration settings and values that are frequently referenced by scripts, business rules, UI policies, and other platform components.
09-11-2025 08:33 PM
Hi @sagarpundir,
The basic difference between these two we can say is -:
System property -> All properties in sys_properties table (OOB + Custom)
Base Property -> Only out-of-the-box properties provided by ServiceNow
I hope this helps
Please mark my response helpful and accept as solution
Thanks & Regards
Mayank
09-11-2025 08:57 PM
Hi @sagarpundir ,
A system property is any configurable key-value stored in sys_properties that controls behavior; a base property is the Out‑of‑Box definition delivered by ServiceNow that serves as the default “source” value before any customer override. “System property” is the actual record/value in the instance that code reads via gs.getProperty().
Base property” refers to the Out‑of‑Box (OOB) property value delivered by ServiceNow as part of the base system.
A system property is a configuration setting stored in the sys_properties table that platform and application code read at runtime
For more detail checkout below article.
System Properties & it's Usage
Bhimashankar H
If my response points you in the right directions, please consider marking it as 'Helpful' & 'Correct'. Thanks!
