Multiple ritm under same request ,but flow is not triggering for all ritm
Apurva127
When we are submitting Request with multiple ritm in it, then flow will not execute for all ritm .
In flow we are simply creating task once we submit catalog item.
so task is not getting create for each RITM.
Attached screenshot for reference
Thanks for your efforts
try adding ritm more that 10 in one request ,then may be issue will come .
because i was facing issue when adding ritm more than 10.
Hello @Apurva127 ,
its still working. I added 15 times and there will created 15 ritms and for each ritm task is created .
Hello @Apurva127 ,
Does your query is resolved ?
Hello @Apurva127 ,
I hope you are doing well . Does my response helps you ?
If my response helps you then mark it as helpful and accept as solution. This will helps  further future queries.
Aditya,
Technical Consultant
