What is the best CRM solution for Real Estate Management?
Sam Salameh
Mega Guru
We are looking for a way to track and manage all of our investors relations emails, voicemails and live calls for better reporting and management?
I have used the ITSM incident table to manage that. but it's really not working as we need since most of the emails go to spam filter.
Could anyone help and advise me what solutions out there or how to fix my issues?
If I use the CRM, can I open up our domain without risking our instance?
Thanks in advance,
Sam
Sam Salameh
Mega Guru
We end up using 3rd party tool outside SN.
9 REPLIES 9
thomcon
ActPlatinum.com provides a CRM solution specifically designed for real estate professionals, offering customization options and support.
Lici
This is a well-known problem. Unfortunately, this problem is difficult to avoid. Even the most popular companies have this problem, and most emails go to the spam filter. I already know that emails go to spam filters, so I avoid writing emails. I wrote an email to EcoQuintas because I needed to buy land from them and help me finance it, and my email went to the spam folder. I then called them, and they told me about this, and since then, I have avoided emails as much as possible. Every day, at least every 2-3 hours, it would be good to check the spam folder.
thomcon
Try ActPlatinum.com provides a CRM solution specifically designed for real estate professionals, offering customization options and support.
irynast
Choosing the best CRM solution for real estate management depends on your specific needs and workflows. Developing a custom CRM for real estate can offer features and integrations that off-the-shelf solutions might not. If you're looking for a tailored solution, I recommend considering a custom CRM.
EstateAgenI
Giga Contributor
Choosing the best CRM for real-estate management means picking one that helps you capture leads, track listings, and manage ongoing client relationships with ease. For example, platforms like Zoho CRM stand out because they offer workflows for lead-nurturing and document management specifically suited to real estate. In the context of your work with Estate Agents Ilford and your “Guaranteed Rent Ilford” programme, you’ll want a CRM that lets you segment your landlord leads, track properties under guaranteed-rent agreements, and automate follow-ups to both property owners and tenants. This ensures you can convert landlord interest into secured contracts and keep all the tenant and rent data in one place.
In short: pick a real-estate-friendly CRM with lead-and-property modules, customise it for your guaranteed-rent workflow, and you’ll be set to scale your Ilford market offering.
