ACL Issue in Flow When the Flow is triggered by the System
03-20-2026 02:02 AM - edited 03-20-2026 02:17 AM
Hi All/ @Ankur Bawiskar
I have a flow which is triggered at 4:00 AM GMT. Now in that flow I am using look-up record for the table X and then sending an email using Send Email Action. In Send E-mail body I am using Table X record attributes using data pili picker. When I am testing the Flow using Test UI Action in flow I am not facing any issue. My Flow Properties is set as Run As - User Who initiates the session.
However, when the flow is getting triggered by the system at 4:00 AM GMT. I am getting an error while sending email.
I tried to change the Flow property to Run As - System User. Now when I am testing it manually through UI Action I am getting the same ACL error.
My understanding is when the flow is initiated by the system then the all the ACL's are evaluated to true.
Error: Email validation failed: ACL restricts retrieval of the record: Table Name of X Sys_ID of the table record
Note: The Flow and Table X both are in same application.
03-20-2026 04:18 AM
Hi @Ankur Bawiskar ,
We have Table level ACL for CRUD. Allow If 4 ACL CRUD operation and Deny Unless 4 ACL CRUD.
In All Deny Unless ACL we have Security Attribute UserISAuthenticated.
Rohit
03-20-2026 08:46 AM
So we have CRUD ACL on table for Allow If (record) with roles and then CRUD ACL for deny unless (record) for which we have security Attribute as UserIsAuthenticated.
04-01-2026 06:13 AM
04-01-2026 06:29 AM
sorry can't help much since no access to instance.
please debug or raise a case with ServiceNow
