Add Attachment through portal with using ATF
10-09-2020 02:03 PM
Currently I am working in Paris version, I am trying to test add attachments things through portal with using ATF but I am getting weird errors. I am attaching pictures also, Can any one help me on this please.
Errors: 1) Invalid Table ( Please look at the Pictures 1 and 2)
2) Step does not have any attachments. Each 'Add Attachment' step requires at least one attachment to upload ( Please look at the Pictures 3,4 and 5).
Thanks in Advance.
03-03-2021 03:56 AM
Hello
Even I am facing similar issue while attaching a doc during submission of a request in portal using ATF. Did you find a solution or workaround to this failure step ? If yes, please let me know what it is! Thanks!
Supreeth R
03-03-2021 04:23 AM
Currently you can add files as attachment using "Add Attachments to Form (SP)" but I haven't explored on that much
03-03-2021 05:13 AM
03-03-2021 05:16 AM
The functionality has some limitations.
05-24-2021 10:51 PM
Did we got any solution for the above mentioned atf attachment related issue? Even i have tried the same, but i could attach any file in record producer eforms in Portal. Since my eform has an mandatory attachment option, because of this issue i could not submit the eform.
Can any one help me on this?
