Add Attachment through portal with using ATF
Eeshwar
Currently I am working in Paris version, I am trying to test add attachments  things through portal with using ATF but I am getting weird errors. I am attaching pictures also, Can any one help me on this please.
Errors: 1) Invalid Table ( Please look at the Pictures 1 and 2)
              2) Step does not have any attachments. Each 'Add Attachment' step requires at least one attachment to upload ( Please look at the Pictures 3,4 and 5).
Thanks in Advance.
13 REPLIES 13
Starting from Quebec you can add attachment to Catalog Item or Record Producer using the Add Attachment test step
Zach3
Has anyone on Paris been able to resolve this issue? We're also running Paris and experiencing the same issue with the "Add Attachments to Form (SP)" step returning an "Invalid table: " test step failure. No other error logs or diagnostic details seem to be available.
Obviously, this is problematic because we are trying to test a portal record producer with a mandatory  attachment. If we can't test the mandatory attachment requirement, then we can't test the record producer.
Any assistance or information would be appreciated. Thanks!
Jesus9
Hi Zach im having the same issue, were you able to fix it?
Ravi Sharma
Hello Eeshwar,
Even i am also facing the same issue. Did you got the solution?
