Anyone else having problems getting MFA to work?
shawnbaar
Giga Expert
I just enabled the Integration - MFA plugin and made sure the property Enable Multifactor Authentication was checked.  I then went to a user and added the Enable Multifactor Authentication field to the User form and checked it.  However, when trying to login as that user, they are never prompted to use the MFA feature, no matter how many times I log them out and back in.
Has anyone else experienced this previously or know what I might have skipped?  I looked at all the documentation until my eyes bled trying to see if I did overlook something, but I feel like I did it all.
Shawn
mohit_rathore
Did you find a solution? I'm facing the same issue with MFA not prompting after the first successful authentication. If you have a fix, could you please share it?
