Can you use the greater than condition for flow designer catalog variables?
Kevin S1
I'm working on a subflow in the Flow Designer and ran into an issue when using a catalog variable as the data pill.
I used the "Get Catalog Variables" action to get the string value of a catalog variable in a previous step.
My question is can we check if the catalog variable(string field) is greater than a hardcoded number and then control our if logic that way? (check screenshot)
Currently, all I see is "is, is not, contains, and does not contain"
I don't see a script option for the "condition part" either.
Am I missing something?
Hi Kevin,
You can create a custom action with script step and evaluate the condition in the script.
Suraj
Simo Shaf
Hi Kilo,
You can create a Flow Variables and then use 'Set Flow Variables' to type this script:
var x = fd_data._1__get_catalog_variables.nameOfvariable
x= parseInt(x);
var more='more';
var less='less';
// Check if the conversion was successful
if (x>=25000) {
return more;
else{
return less;
After that, you can use an 'if' statement to check if the output of that variable is more or less.
