Cannot find "Connection Timeout" parameter for Flow Action REST Step (Quebec)
Steve Moore1
Hi all,
I am running into an issue where the REST step in my Flow action is timing out at 30 seconds.  I took a look at the "glide.http.outbound.max_timeout" and it is currently set to 90 seconds, so I don't believe this is the property that the REST step is utilizing.
My question is, does anyone know where the connection timeout property for the REST Step in Flow Designer is located?
*Note - We are currently in Quebec - I can see that in Rome you can set it manually within the REST Step, but that is not an option until we upgrade in a couple months.
Hello @Steve Moore1, @Ritika Saran3 - I am encountering similiar kind of issue with my Flow. Were you able to find a solution to this?
Hey we also facing this issue. Any recommendations ?
I was able to resolve the issue by creating the com.glide.hub.flow_api.default_execution_time property and setting the value to 60000. This property wasn't well documented but I found it mentioned in a KB article here: https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0860451
