Difference between Worknotes and Watchlist
yeskaytee
What is the differences between Worknotes and Watchlist
Worknotes - people added to this list will get all "Work Notes" updates. Used for internal communication (usually Requestor not included).
Watchlist - people added to this list will get all "comments" update.
Is there any other difference?
Uncle Rob
No, but that difference is pretty significant.
You can think of work notes is as you and your team discussing the technical minutia of fulfilling the task.   Stuff the customer needn't know, but executors might.
Comments / Watch_list on the other hand is you discussing the work with the consumer formally.
Comments = "customer" visible.
Work Notes = "just between us workers"
"Customer" is treated differently task type to task type.  Projects and Project Tasks really blurs the line.  There really is no "customer" concept.  That's likely why it was left off.
But since Project and Project task ultimately extend Task, they inherit the fields, whether or not they're actually used.
khushboo14
thank you robert
lhuerta
How can i adjust my Work notes to not be visible to the customer? They are currently visible.
Mohammad Nayeem
You will have to adjust the read ACLs on the work_notes field to itil role and member of assignment group. This will deny read access to customer/submitter automatically.
