Display Variables on Task Form on Request Item using Flow Designer
Nic Nagtzaam
Giga Guru
inside the old workflow editor there was a function that enabled you to display Variables from the Task Form on the Catalog Task form
I am trying to figure out the same capability using flow designer as i have developed a series of workflows using flow designer for the service portal.
Does anyone know how to do this?
Kind Regards
Nic Nagtzaam
Thank you so much  @Michael Jones - . I was using Create Task as an Action and I couldn't see the catalog variables. By the time I switched this to Create Catalog Task the option for Catalog Variables was displayed.
