Empty values for macro in variable editor
harshvardhan_11
Giga Expert
I have created a UI macro, having an input field, which I am using in a variable in record producer.
After submitting the item, and checking record created. The variable editor have empty values in those input fields.
How should I bring the data entered in UI macro variable to the variable editor. I want to show exact same field data with the same style in record table.
What I am saying is that your input field "<input type="text" name="newsal" />" is in the context of the macro, and not the Record Producer, so the producer script I don't believe can read that value and do anything with it. You would actually need to have an onchange script in your macro write the value to a variable in your producer (the variable can be hidden) so that it is available to the producer script.
In macro, you have to write a <script> tag having a function which add the value of all the fields (of macro) to a string in a format which you need.
Then in the record producer, you can write an onSubmit Client Script which calls the above function and pass that string value to a multi line text.
I have achieved my requirement using the above.
But just to update, there is a service now solution in Service Now share named "Catalog Table", which helps to add a table(grid) in catalog. And it also shows the value in variable editor. Sharing one link where you could get some details related to it.
Catalog Table Variable - fixes and improvements including multiple variables on the one form
