Flow - Checking if incident exists
Damian Martinez
Hello, I hope everyone is ok and safe, Happy New Year, all the best for 2022.
I have a flow with logic to create or update an existing incident.
The logic is simple:
1. look up the incident record
2. if the incident exists (I have some conditions there) then, update it.
3. If incident does not exist, create a new one.
The issue I have is that it creates a new one every time, because I can't check if the incident record exists.
I tried the solution from this post: https://community.servicenow.com/community?id=community_question&sys_id=9a2359a7db28bfc014d6fb24399619bf
However I don't have the option for If count is 0, so I can't add that condition.
Does somebody know what I'm missing?
is count not available for look up records incidents?
Thanks in advance!
Hello Olan,
Thanks so much for providing that example, I'll give this a try and let you know how it goes.
Best Regards.
