‎02-07-2025 02:24 AM
Hi Experts,
We have a requirement to get approvals based on the location selected on the form. We have two variables "Moving From" and "Moving To" Both are reference variables to the "cmn_location" table. So, based on the location selected in these two fields, we need two group approvals from the location table (primary support field on loction table referencing group tabel) simultaneously.
Conditions to check:
1. If any of the locations selected has no "primary support" group, default approval to the service desk.
2. If both "Moving from" and "Moving to" has same "Primary group" then only one group approval required.
3. If "Moving from" and "Moving to" have two different groups, then two group approvals simultaneously anyone from each group should approve.
I searched in the community, but no luck. This is a priority one so quick reply is highly appriciated.
‎02-07-2025 02:56 AM
Hello @Sagar Garige
You can do it with flow try to give a start. Below is pseudo format for your flow while designing. If stuck or block do share with us will try to guide you.
Start
├─ Retrieve "Moving From" primary support group (MF_Group)
├─ Retrieve "Moving To" primary support group (MT_Group)
├─ Check if MF_Group OR MT_Group is NULL
│ ├─ Yes → Set Approval Group = Service Desk
│ └─ No → Check if MF_Group == MT_Group
│ ├─ Yes → Set Approval Group = MF_Group
│ └─ No → Set Approval Groups = MF_Group & MT_Group (both required)
└─ Submit for Approval
└─ Wait for Approval(s)
└─ Proceed based on outcome (Approved/Rejected)
Thanks & Regards
Viraj Hudlikar.
‎02-07-2025 03:25 AM
You will have to use multiple IF logic in flow for your 3 checks.
OR
Another way is to use Flow variable and use scripting and store the approval group in flow variable and then use that in Ask for Approval flow action
‎02-10-2025 05:29 AM
