Flow designer is not opening in Operations view
ellendulash
I'm trying to open the operations view/execution details of a flow in my PDI, but it is not opening. I'm only able to view below provided screenshot.
I had the same blank screen issue when trying to activate changes made to a subflow.
I found a work-around where you can use the workflow studio homepage to search for the subflow in question. The "Status" column should show draft. You can use cell edit to change that status value to published and that did the trick for me.
I also have the issue with viewing workflow context in operation view but do not have a resolution for that.
Giovanni Perett
Please, try to update the Workflow Editor plugin to the latest version.
With Wa release, i solved updating the plugin.
Thank you.
Thanks. It worked.
M_iA
There is an incompatability issue between SN and the plugin.
The issue here is incompatible version of "Unified Developer Core" ( Appshell) with Workflow Studio .
Unified Developer Core is upgraded to 25.1.5 by "Table Builder".
Workflow Studio version in instance is 25.1.3 and the compatible Unified Developer Core version is 25.0.6
If you upgrade to at least Washington patch 3 and then upgrade the workflow studio plugin, this will fix your issue
Joshua Prakash
Upgrade your workflow studio or Upgrade the instance to Xanadu.
Worked for me
