Flow Designer - "Wait for a duration of time" - does it work if variables have updated since original "Get Catalog Variables" lookup??
catherine_s
We have a Catalog Item where there will be a variable for "due date" that triggers a new task. We are using Flow Designer.
In this business scenario, there is a valid case where the due date could be changed. I was originally planning to use "wait for duration of time" and set it relative to the Due Date variable.  Does "wait for a duration of time" check the current value of the variable or does it take the original value from when we did the "Get Catalog Variables" lookup?
I was thinking another option may be to do a daily check to see if the due date has changed but this seems like a lot of unnecessary overhead, but it might be necessary if the flow uses the original due date value on the "wait for duration of time".
Thanks for your advice or ideas on this,
Catherine
11 REPLIES 11
Hi @mukesh__kumar
I also have same requirement, did you figure out the solution for this?
Pvn1
Hi @mukesh__kumar
Did you ever get a solution for this?
