Function within Script Include is not working
Satpal Singh1
Hello All,
I know this is very simple code in server side script but why it is not working I am very amaze.. .
gs.print('I am running '+ this._gettest('da','Hello Sir'));
function _gettest(target,query) {
  gs.print(target + query);
Thanks all !!
SS
11 REPLIES 11
Please keep it simple when you are learning   Try this code first, If it works then you expand code.
Just add a single function in your script include.
maintest: function() {
      gs.log("Inside maintest function of Script include");
      return "my response";
Please Hit like, Helpful or Correct depending on the impact of the response.
BALAJI40
This can be in the script include function, gs.log('I am running '+ this._gettest('da','Hello Sir'));
you can write after the script include function exclusively,
_gettest: function (target,query) {
  gs.log(target + query);
try with this.
