g_form.clearValue() does not work in the catalog client script
Kalyani35
HI experts,
Using a onchange client script(onchange of variable month_of_overtime) I want to clear the selected value in the selectbox type of a variable in a variable set based on the response received from the Glide Ajax call. Everything works fine as expected but, as soon as I add the statement to clear the selectbox variable it throws an error on the form.
Please look at the screens shot below.
Screenshot of error:
If I remove the clearValue statement the error message does not appear.  What could be the reason for this?
Note: the Script include is returning correct value so nothing is wrong there.
13 REPLIES 13
Hi Kalyani,
your client script call on variable set not on catalog item correct???
PavanK960672992
Mega Patron
have you selected the UI type as ALL?
If not please select UI type as All in Onchange client script.
Pavankumar
If it helps please click Accept as Solution/hit the Thumb Icon.
ServiceNow Community MVP 2024.
Pavankumar
Hi Pavan,
 I have selected it to All.
please share your script screenshots will not help us.
Try to add below code in your client script and add field message as well in if loop
ajaxRoles.getXMLAnswer(getRolesinfo); //callback function
    function getRolesinfo(response) {
        if (answer == 'false') {
            g_form.clearValue('month_of_overtime');
if not resolved please share client script and script include or
If you are using chrome then use ctrl+shift+i to open developer console. see error
Pavankumar
Pavankumar
Onchange cs:
    var otmonth = g_form.getValue('month_of_overtime');
    var ajaxRoles = new GlideAjax('sn_hr_core.XXXXXXXXXXXXXX');
    ajaxRoles.addParam('sysparm_name', 'isCorrectOvertimeMonth');
    ajaxRoles.addParam('sysparm_app_otmonth', otmonth);
    ajaxRoles.getXML(getRolesInfo);
    function getRolesInfo(response) {
        if (answer == '0') {
            g_form.showFieldMsg("month_of_overtime", "You are allowed to select only past 2 months.", "error");
Script include function:
isCorrectOvertimeMonth: function() {
        var otmonth = this.getParameter('sysparm_app_otmonth');
        var currentTime = new GlideDateTime();
        var currentMonth = currentTime.getMonthUTC();
        if (currentMonth > otmonth) {
            var monthDiff = currentMonth - otmonth;
            if (monthDiff > 2) {
                return false;
                return true;
            return true;
