g_form removeOption does not work on catalog variable
tkaneko
Giga Contributor
I am trying to remove an option from a select box on a catalog variable but it does not remove. The script is:
    if (isLoading) {
  g_form.removeOption('eai_reviewer_sel_next_task', 'eai_research');
  //g_form.clearOptions('eai_reviewer_sel_next_task');
  //g_form.addOption('eai_reviewer_sel_next_task', 'uat_implement', 'UAT Implementation');
  //g_form.addOption('eai_reviewer_sel_next_task', 'prod_implement', 'PROD Implementation');
The g_form.clearOptions and g_form.addOption functions seem to work fine but the g_form.removeOption does not.   I would prefer to not clear all options and add back the ones I need as I need to include the 'none' option and its setMandatory properties.
nickbuhl
In case you are still having this problem or someone else stumbles upon this, I was having a similar problem with getControl(), clearOptions() and removeOption() not running on Catalog Tasks or Requested Items when I found this article.
ServiceNow KB: The g_form.getControl method does not work after ordering (KB0547171)
I added the suggested code below to my client scripts and used form.removeOption instead of g_form.removeOption.
var form = typeof g_sc_form != "undefined" ? g_sc_form : g_form;
30 REPLIES 30
Joe Taylor
Giga Guru
This was resolved by a work-around provided by ServiceNow.  I had to put in a slight delay timer into my Catalog Client Script:
//Remove Power_BI subcategory after 1/2 second
setTimeout(function() {
//alert('click to remove Power_BI subcategory');
g_form.removeOption('subcategory','Power_BI');
}, 500);
