02-01-2019 11:22 AM
I'm having issues with ServiceNow Groups sys id's, Where Dev, Test, Prod groups sys ids are different. When I Pushed my workflow updates to test they have different sys ids. What is the best process to maintain them Unique Sys ids?
Notifications
Service Catalog
Workflow
02-01-2019 11:29 AM
You have to push XML's of the groups through instances to maintain same sys_id's.
It is not advised to create groups manually across all instances.
02-01-2019 11:35 AM
Yes that's correct. This helps in maintaining same sys_ids across all instances.
Please mark this post as helpful or the correct answer to your question if applicable.
-Cheers
Prateek
