HasRole Condition in flow?
Marvin16
is there any easy way to have an "user.hasRole("myRole") condition within the flow designer? I cannot find anything to check for user roles 😞
best regards
yes for that you have to add custom action here
If my answer helped you, kindly mark it as correct and helpful.
Priyanka136
Mega Guru
Hi Marvi,
Can you please elaborate more about your requirement ?
Priyanka
I have a user record within my flow. So i want to check whether this user has the role admin for instance and i cannot find an easy way to do it. Sure i can query the role table but is there no simple way to do it ? I thought there might be a core action for that but cannot find any 😞
