Help!!!Reference icon viewable for readonly field
SRJ
HI ,
requirement says, user can view Requested item reference icon on catalog task form. But field should be readonly. Any suggestion please
thanks
tanumoy
Check for the system property and make it true
glide.ui.reference.readonly.clickthrough
This will enable the hover icon for readonly reference fields.
SRJ
thanks very much Tanumoy and Chuck:)
You are very welcome. I'm glad you got your question answered. Thank you for participating in the community.
