Help with App Engine Pipeline configuration. Will not validate
tomhamill
I get the following error when trying to validate a pipeline in my new PDI.:
Could not connect to the environment. [Method failed: (/api/sn_pipeline/pipeline/validate_connection) with code: 401 - Invalid username/password combo]
Not sure where to look to validate the username/password combo.
TaniaC322
Giga Contributor
I am having the same issue when trying to create the 3 environment to create the pipeline so i can finally use the ACE
Anshu10
Hi ,How was it resolved ? Can you please suggest. We are facing the same issue.
In my case I was able to resolve the issue by adding the ADMIN role to the functional user (Web service access only) in all the environments.
As @Marc Mouries mentioned above, go to App Engine > Environments and check the credentials of each environment. More specifically, don't forget to add the ADMIN role to the functional user that is required for the credentials.
