How can I call Script include and Business Rule from Flow designer using f(x) scripting box?
Sontel
I have a BR and script include which sets the Due date on a catalog task.
How Can I call these scripts from flow designer? What is the format to be used while calling these scripts from f(x) scripting block provided in Flow designer?
Ankur Bawiskar
it's the same
Just ensure you return the valid value matching the field type
var value = new ScriptInclude().functionName();
return value;
Ankur Bawiskar
it's the same
return value;
@Sonesh Patel
If my response helped you please mark it correct to close the question so that it benefits future readers as well.
