How to build auto refresh into UI Components
ArtturiP
I'm building a component and I'm having hard time figuring out auto refresh.
The requirement is this:
  • Component should be refreshed if there hasn't been user interaction for a set time
  • If user interacts (changes the content that is shown), the refresh counter should reset
Currently the component takes in data via API call directly from the component (yes I know, not the ideal way, however the data fetching requires some intense heavy lifting, and it needs to be handled in scripted rest api).
What I have tried so far:
  • Get the data via data resource (does not help, using data resource itself does not autorefresh)
  • Connecting setTimeout to component's state, and clearing it in case of user interaction
    --> This was my favourite route, but due to reason I don't understand, I can't use dispatch function asynchronously. It leads to error "dispatch is not a function". Screenshot attached.
@Brad Tilton , I feel no shame in tagging you here, as you seem to be the one who leads the community in this area =).
ArtturiP
Was able to solve it. I was on the right track, but the problem was my insufficient understanding of async javascript technicalities. One can not directly pass the parameters into callback function when setting setTimeout; they should be included as additional parameters into setTimeout -function.
This solves the trick:
function timeOutFunction(disptachFunction, dispatchParm1, dispatchParm2) {
    console.log("timeout triggered");
    disptachFunction(dispatchParm1, dispatchParm2)
And to actionhandlers:
TIMELINE_DATA_RECEIVED: ({ state, properties, action, updateState, dispatch }) => {
updateState({
items:action.payload.result,
showLoading:false,
timeOut:
setTimeout(timeOutFunction, 5000,dispatch,'REFRESH_VIEW',{
date_diff:properties.dateDifference
I'll do a proper blog post about this later.
Available here 😃
https://community.servicenow.com/community?id=community_article&sys_id=023906771b6d49100ccc85176e4bcb4e
