How to do a global search for keywords in a flow designer flow/subflow/action?
wclim
Hi all,
I like to know an easy way to do a search within Flow Designer flows/subflows/actions to find a keyword. Let's say I know there could be a flow that edits a custom field (u_custom_field) on the incident table, but am not sure which exact flow is it and I like to find out which flow is it, is there a keyword search for such cases?
For the more 'traditional' configurations like business rule, it is easy to do this keyword search
E.g. Let say I like to do a search on Incident business rules to see which configurations are using a custom field (u_custom_field), I can easily type it in the Search 'for text' and it will return results containing the keyword, be it in the conditions, scripts etc
I can also go to the sys_metadata table and do the same keyword search if I'm unsure which config might contain this keyword.
However, I don't see an easy way to search the flows/actions/subflow in the flow designer, and it also doesn't seem that searching on the sys_metadata returns anything i need for flows/actions/subflow.  So is there a way to do keyword searches for flows/subflows/actions?
Looks like there is no good way to do a full keyword search for flows/subflows/actions in flow designer, since the keyword search does not search everything within the flows.
So I will have to use the current way of opening flows individual to review the flow if I like to search for keywords.
Harshal Gawali
Giga Guru
Hi wclim,
In flow designer page, you can see the search "for text" option given there. Please refer below screenshot.
Harshal.
Hi Harshal,
I forgot to mention, that Search in the screenshot doesnt search the whole flow.
One example will be if my keyword is in a scripted value like the one below belonging to a Update Record action, the flow does not appear if try to search for the keyword like that from your screenshot, this may be misleading that I will think that none of the flows contains that particular keyword.
Not sure if there are any other examples like that at the moment.
So I would like to see if there any better ways to doing such a keyword search for Flows/Subflows/Actions.
bsy6379_0-1724750428132.pngNo search bar
DilipKumar DJ
Hi, You will not be able to do that for the flow designer as the content which is decrypted is not exposed. Certain things can be searched by listing sys_hub_flow and referring field "Label cache" to find table , action , subflow etc. But even that will not be at script level.
