How to return a value from a script step in flow designer.
Sonu Singh
Mega Expert
I need to fetch a value from the response body which i have received it from the SOAP step:
Fig:
Can some help me how do i fetch any value from the xml response which i am getting in the responsebody input variable?
Ak
So the problem is the body which is returned from integration.
See formatted XML
Below works but it's not good for long time solution.
var response = inputs.response_body.toString();
var xmldoc = new XMLDocument(response);
if(xmldoc.toString().indexOf('name=') > -1){
	var nm1 = (xmldoc.toString().split('name="')[1]);
	var nm2 = (nm1.toString().split('"')[0]);
	outputs.groupname = nm2;
41 REPLIES 41
Hello Ak,
Did you create a variable with group name under output variable section in a script step? If not please create a output variable with name as groupname.
- Pradeep Sharma
Hi @Pradeep Sharma
Yes, i have created it..
 From the SOAP step i am getting an response like this:
<?xml version="1.0" encoding="utf-8"?>
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<soap:Body>
<GetSupportSpecialistByLocationResponse xmlns="http://nda.sys.com/">
<GetSupportSpecialistByLocationResult>
&lt;nda-response id="getassociations" status="OK"&gt;
&lt;association&gt;
&lt;people&gt;&lt;/people&gt;
&lt;groups&gt;
&lt;row name="India - Banaglore" email="indbgl@xyz.com" /&gt;
&lt;/groups&gt;
&lt;/association&gt;
&lt;/nda-response&gt;
</GetSupportSpecialistByLocationResult>
</GetSupportSpecialistByLocationResponse>
</soap:Body>
</soap:Envelope>
from this i want to fetch  "India - Banaglore" and pass it to the Outputs.groupname
which i am not able to achieve it.
Ak
Gaurav Shirsat
Hi Ak
This Thread might help you.
You can create a JSON object to return multiple values like below
var obj = {};
obj.approver = gr.manager.toString();
obj.approver = gr.user1.toString();
obj.approver = gr.user2.toString();
do refer the below links
https://community.servicenow.com/community?id=community_question&sys_id=1bbde7dbdb4eef8011762183ca96...
https://community.servicenow.com/community?id=community_question&sys_id=b2fe56631bda0010a59033f2cd4b...
Please Mark Correct and Helpful
Thanks and Regards
Gaurav Shirsat
Mike Patel
Tera Sage
try doing instead of gs.print map it to whichever field you want.
var response = inputs.response_body;
var name = xmldoc.getNodeText("//row/@name")
gs.print(name);
Hey @Mike Patel ,
I am not able to map it.
Execution detail:
