How to return a value from a script step in flow designer.
Sonu Singh
Mega Expert
I need to fetch a value from the response body which i have received it from the SOAP step:
Fig:
Can some help me how do i fetch any value from the xml response which i am getting in the responsebody input variable?
Ak
So the problem is the body which is returned from integration.
See formatted XML
Below works but it's not good for long time solution.
var response = inputs.response_body.toString();
var xmldoc = new XMLDocument(response);
if(xmldoc.toString().indexOf('name=') > -1){
	var nm1 = (xmldoc.toString().split('name="')[1]);
	var nm2 = (nm1.toString().split('"')[0]);
	outputs.groupname = nm2;
41 REPLIES 41
the xml doesn't have proper starting and closing tags i.e. < and >
If the response is proper as below; you should be able to get the value as below
Please update code as below
// ... code ...
var responseBody = inputs.response_body;
var xmldoc = new XMLDocument(responseBody);
var name = xmldoc.getAttribute("//row", "name");
var email = xmldoc.getAttribute("//row", "email");
outputs.groupname = name;
})(inputs, outputs);
Sample script which I ran in background script
var xml = '<?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><soap:Body><GetSupportSpecialistByLocationResponse xmlns="http://nda.sys.com/"><GetSupportSpecialistByLocationResult><nda-response id="getassociations" status="OK"><association><people></people><groups><row name="India - Banaglore" email="indbgl@xyz.com" /></groups></association></nda-response></GetSupportSpecialistByLocationResult></GetSupportSpecialistByLocationResponse></soap:Body></soap:Envelope>';
var xmldoc = new XMLDocument(xml);
gs.info(name);
gs.info(email);
Hi @Ankur Bawiskar
I am getting the below response from the soap.
I copy pasted the rendered HTML in background script and  execute it with the below script, where i got the output.
var response = inputs.response_body;
var name = xmldoc.getNodeText("//row/@name")
gs.print(name);
below are the same response which i got from soap step.
so i question is how can i pass Rendered HTML thing to script step so that i can fetch any node.
@Ankur Bawiskar ,
on passing the soap response to xml parser i am getting the response as below:
"Envelope": {
"Body": {
"name$": "Body",
"GetSupportSpecialistByLocationResponse": {
"name$": "GetSupportSpecialistByLocationResponse",
"GetSupportSpecialistByLocationResult": "&lt;nda-response id=\"getassociations\" status=\"OK\"&gt;&lt;association from_entity_guid=\"123456789\" business_process_role_guid=\"123456789\"&gt;&lt;people&gt;&lt;/people&gt;&lt;groups&gt;&lt;row group_guid=\"123456789\" name=\"IND - BGL\" email=\"indbgl@xyz.com\" ordinal=\"0\" description=\"\" association_guid=\"123456789\"/&gt;&lt;/groups&gt;&lt;/association&gt;&lt;/nda-response&gt;"
if i pass this response to Script step, can i fetch those values?
regards,
Ak
so now you are converting xml to json?
