How to return a value from a script step in flow designer.
Sonu Singh
Mega Expert
I need to fetch a value from the response body which i have received it from the SOAP step:
Fig:
Can some help me how do i fetch any value from the xml response which i am getting in the responsebody input variable?
Ak
So the problem is the body which is returned from integration.
See formatted XML
Below works but it's not good for long time solution.
var response = inputs.response_body.toString();
var xmldoc = new XMLDocument(response);
if(xmldoc.toString().indexOf('name=') > -1){
	var nm1 = (xmldoc.toString().split('name="')[1]);
	var nm2 = (nm1.toString().split('"')[0]);
	outputs.groupname = nm2;
41 REPLIES 41
i am getting the response with :
&lt; for <
and &gt; for >
i tried to replace this thing to proper  xml tag but that also i didn't get.
@Ankur Bawiskar  & @Mike Patel
Can we fetch the render HTML from the above pic, because there i could see all proper and closing tags?
try below and see what you get in logs
gs.log("response: " + response, "Soap");
gs.log("xmldoc: " +xmldoc, "Soap");
var name = xmldoc.getNodeText("//row/@name")
gs.log("name: "+name, "Soap");
here is log details @Mike Patel ,
Can you copy that xml and share, I can test something and if it works then I'll let you know.
@Mike Patel
response:
<?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><soap:Body><GetSupportSpecialistByLocationResponse xmlns="http://nda.acml.com/"><GetSupportSpecialistByLocationResult>&lt;nda-response id="getassociations" status="OK"&gt;&lt;association from_entity_guid="12345D3E-AFD1-19B1-1FD0-R3R0BF3A11EB1" business_process_role_guid="12345D3E-AFD1-19B1-1FD0-R3R0BF3A11EB1"&gt;&lt;people&gt;&lt;/people&gt;&lt;groups&gt;&lt;row group_guid="12345D3E-AFD1-19B1-1FD0-R3R0BF3A11EB1" name="IND -BLR" email="indblr@example.com" ordinal="0" description="" association_guid="12345D3E-AFD1-19B1-1FD0-R3R0BF3A11EB1"/&gt;&lt;/groups&gt;&lt;/association&gt;&lt;/nda-response&gt;</GetSupportSpecialistByLocationResult></GetSupportSpecialistByLocationResponse></soap:Body></soap:Envelope>
