How to select a related links using atf test steps
asha23
how to submit risk assessment form using ATF test steps on change ticket. Using "Click UI Action " I only be able to select UI buttons. Pease advise
Hi Paul
Apologies for late reply. I managed to sort it out. Turns out, before you retrieve the components, the last run must be successful, with no errors.
Hi paul, i am trying to add incident to a problem record and test it using at. There is a edit button in the related links but I am not able to select that UI butoon. What I am doing wrong?
symonflores_23
Hi, got the same problem. Do you have the fix for this?
