10-12-2020 04:36 AM
We are using the Jira Spoke in Orlando version.
Trying to figure out how to update specific fields on a Jira Issue with the "Update Issue" action.
I see "Add Labels" and "Remove Labels" and "Additional Fields"... but does anyone have any examples of how to do that?
Shivanki Jain
Flow Designer
IntegrationHub
10-12-2020 04:42 AM
Update Issue will only update specific fields
refer below link for help
How to Set up a ServiceNow Jira Integration: the Comprehensive 2020 Guide
10-12-2020 07:16 AM
Since this spoke is not available freely I cannot test this on my PDI.
you need to explore more on this by checking docs etc
05-07-2021 10:32 PM
If my response helped you please mark it correct to close the question so that it benefits future readers as well.
01-11-2021 10:42 AM
Hi Shivanki,
I had trouble with this as well. The following KB helped:
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0818189
06-28-2021 12:35 PM
Hi
Any idea where it is going worng? we have valid connection and able to update when provide hardcoded issue id
Error: Unexpected token in object literal,Detail: Unexpected token in object literal
06-29-2021 05:47 AM
hey @santosh kumar,
I faced same issue. you can follow the same link & modify your flow
Shrutika
