How to use metrics for First call resolution for Sc_task
sayali97
Hi Team ,
I have requirement to create FCR for the sc_task where assignment group is ABC and reassignment count is 0. If we create the field FCR on RITM and calculate for sc_task record? How to configure so that it also reportable.
Renat Akhmedov
Hi @sayali97,
If you want to measure First Call Resolution (FCR) for SC Task (sc_task), you don’t need to use Metrics for this scenario.
FCR is simply a true/false condition based on:
Assignment group = ABC
Reassignment count = 0
Task is closed (usually required)
The right way is to calculate FCR on the RITM or on the SC Task itself and make it reportable using a field, not Metrics.
Here is the way:
1. Add a field on sc_task (boolean) → u_fcr
Create a boolean field:
Table: sc_task
Type: True/False (Boolean)
This makes the value easy to report and filter on.
2. Set the value automatically using a Business Rule (or Flow as you wish, I prefer BR):
Create an After Update BR on sc_task:
Conditions:
When state changes to Closed Complete (or your closure state)
BR example:
if (current.assignment_group == 'sys_id_of_ABC_group' &&
    current.reassignment_count == 0) {
    current.u_fcr = true;
    current.u_fcr = false;
If my answer was helpful, please don’t hesitate to give it a thumbs-up - it only takes a second, but it means a lot to me. Thank you!
Best regards,
Renat Akhmedov
MaxMixali
Hi if I understand well your problem, you should try to do this several steps:
1. Create the Custom Field on RITM
First, create a custom field on the Requested Item (sc_req_item) table to store the FCR status for the relevant task(s).
  • Navigate to System Definition > Tables and open the sc_req_item table.
  • In the Columns related list, create a new field.
  • Field name: u_fcr_status_abc (or a meaningful name)
  • Type: True/False (Checkbox) is simple and reportable.
  • Default value: False
  • Save the field.
2. Create a Business Rule on sc_task
Next, create a Business Rule on the Catalog Task (sc_task) table that runs when a task is updated to meet your FCR criteria.
  • Navigate to System Definition > Business Rules.
  • Click New and configure the rule:
    • Name: Update RITM FCR status for ABC group (or a meaningful name)
    • Table: sc_task
    • Active: Checked
    • Advanced: Checked
    • When to run: After Update (After ensures the sc_task is saved with the correct state/reassignment count).
    • Condition: Assignment Group is ABC AND Reassignment count is 0 ANDState changes to Closed Complete (or the appropriate final state). The exact condition depends on when you consider the FCR criteria met.
  • In the Advanced tab, use the following script:
    javascript
       var ritm = new GlideRecord('sc_req_item');
       if (ritm.get(current.request_item)) {
          // Check if the current task meets the FCR criteria
          if (current.assignment_group.getDisplayValue() == 'ABC' && current.reassignment_count == 0 /* && current.state == '3' (Closed Complete) */) {
             ritm.u_fcr_status_abc = true; // Set the custom RITM field to true         ritm.update();
    })(current, previous);
    3. Reporting on the Field
The custom field u_fcr_status_abc is now a standard field on the sc_req_item table. It will be readily available for reporting.
  • Navigate to Reports > Create New.
  • Select the Requested Item (sc_req_item) table.
  • In the report conditions, you can filter or group by the custom field:
    • [FCR Status ABC] is True
  • This allows you to report on all RITMs where a specific task for group ABC was resolved with zero reassignments.
Hi @Renat Akhmedov ,
Thanks for the solution but what it for particular 2 catalog items this should be valid not for all
