If script in a workflow to check if list collector is empty
pothukuchirsnh
Kilo Explorer
I am trying to use an ifscript to check if a list collector selected values is empty or not. If it's not empty, I will generate tasks based on the selection.
Right now my script looks like this but I see a warning:
Try this (typo also corrected on line 2)
answer = ifScript();
function ifScript() {
var accessoriesList = current.variables.accessories.toString(); //convert the variable list to string
var arrayList = accessoriesList.split(",");
  if (arrayList.length > 0) {
            return 'yes';
          return 'no';
bhoomikabisht
Kilo Expert
Hi Ravikant,
Please give your script here...
Chuck Tomasi
In lieu of an if script, here is what I suggest:
        var val = current.getValue('watch_list');
        // Check if it is empty
        if (val.nil()) {
                  return "Yes";
                  return "No";
Ankur Bawiskar
Hi Ravikant,
Use an if condition in the workflow and assuming that your workflow is on RITM table here is the script you can use:
use your variable name in the variableName highlighted in bold.
        var val = current.variables.<variableName>;
        if (JSUtil.nil(val)) {
                  return "Yes"; // is empty
                  return "No"; // not empty
The transition from "No" you can take to Task generation since list collector is not empty
Mark Correct if this solves your issue and also hit Like and Helpful if you find my response worthy based on the impact.
