impersonator does not work for Non-Admin
brianlan25
We are on Jakarta Patch 5 and have user who are ITIL but not full on Admins.   For some reason they are not able to impersonate users.   When they click on impersonate they and try to search for someone it says not matches found.   Any ideas on why this is happening or if this is an known issue with Jakarta?
richardchadd
Please see knowledge article KB0657636:
KB0657636 Non-admin users with impersonator role cannot see users to impersonate except recently imp...
There is following problem to address this:
PRB1244652 Non admin users with impersonator role unable to select any users from the impersonation dialog, except for users in the recent impersonation list
We cannot advise when a fix will be delivered at this time.
Use one of the following workaround methods:
12 REPLIES 12
Yes I have also tested that and that will work during out testing.   I'm not sure we want to be giving any body who might need to be able to impersonate the user admin role once we go live.
jaspalsingh, works like a charm. Thanks!
Mike Colley
Adding the user_admin role was a work around for me.
richardchadd
stevede
Kilo Explorer
For those where KB0657636 does not work, Chuck Warner at ServiceNow recommended the following which did work:
1. Create a new READ ACL sys_user.* and add the role impersonator to the new read ACL.
2. If you have an existing sys_user.locked_out read ACL then you will need to implement the impersonator role addition mentioned above.
