‎09-18-2022 05:09 AM
Hi everyone,
Is it possible to add the minimum characters required to the catalog field of variable type multi-line text?
Eg: I want a user to at-least write 30 characters before submitting.
Priya
Service Catalog
‎09-18-2022 05:57 AM
Use onSubmit()/onChange() catalog client script as per your requirement.
function onSubmit() {
if(g_form.getValue('<multi_line_variable_backend_name>').length < 30){
g_form.showFieldMsg('<multi_line_variable_backend_name>', 'Enter at least 30 characters.', 'error', true);
return false;
‎09-18-2022 05:59 AM
Yes you can validate the length of the variable while submitting the form.
1. Create a onSubmit catalog client script on your catalog item.
try below script
you can add alert or infomessage based on your requirement you can add.
var minLength = 30; //Define the length here
var field1 = g_form.getControl('description'); //Replace description with your variable name
if (field1.value.length < minLength) {
// g_form.addInfoMessage('description should not be less than 30 characters');
alert('Description should not be less than 30 characters');
return false;
Hope you it helps you.
Please Mark ✅ Correct/helpful if applicable, Thanks!!
Pavankumar
‎09-18-2022 09:22 PM
Thank you for the response.
This is working fine when I try it in the ServiceNow catalog.. but in the Service Portal, it's not working, I can submit the form with less than 30 characters also.
Priya
‎09-19-2022 02:59 AM
No it will work in portal as well but you need to select UI type as All in Catalog client script.
Pavankumar
‎09-18-2022 09:21 PM
Hi @Priya
If it is resolved please close the thread by Marking as ✅ Correct so that other readers will get benefit if they have similar question. In future they will refer this question will see solution.
Hope you understood.
Happy learning!
Pavankumar
‎09-18-2022 09:31 PM
Hi Priya,
Instead of writing a client script you can actually achieve just by using Variable validation regex.
Create a record in question_regex table and call it in variable. See below for your reference:
^(?=.*\d).{30,}$
Variable screenshot:
Output:
Hope it helps.
Murthy
