Is it possible to display multiple Process flow formatters on the same form ?
Bphan
Hi community,
I have a question that, Is it possible to display multiple Process flow formatters on the same form?
You can refer to my picture description
Thanks and best regards,
Bach Phan
Mark Manders
Unfortunately, that's not possible. A process flow shows on a record on the table it is designed for, so you can add different fields, but it will show up on the same formatter.
Mark
I think you are right, i read the words here and there.
Unfortunately this is how some of the high responders work on this Community. Just respond as much as possible just to respond. A lot of the responses are also not in-depth, just throwing links, or even utterly incorrect.
This behavior does not help the level of this Community, which is just decreasing.
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
I've been away for a while and was wondering what happened here. Indeed seeing a lot of the same people responding to every ticket (even repeating answers already given) and all are stuctured the same way. Even AI like answers that just don't give an answer.
Hopefully this will change, because you want to get the correct answer from some one that knows the answer or is willing to help you and ask further questions. Not some one that reads half of a question, googles 3 keywords, pastes 3 links and says that it is possible.
Mark
