Is there a way to print a flow designer
JR Guieb
Is there a clean way to print a flow designer.  I have SnagIT 11 and the scrolling window doesn't work.
Naveen20
I opened the flow designer and did ctrl + p and saved it as pdf. You may check the attachment.
Adam43
works on regular view- anyone have luck on Diagram View?
